Displays the status of the fans in the system.
| detail | The detail option is reserved for future use. |
N/A.
Use this command to view detailed information about the health of the fans.
This status information may be useful for your technical support representative if you have a network problem.
Fan information for bridge port extenders (BPEs) does not appear in this command. Use the show vpex bpe {slot slot_num} {environment} command instead.
The following command displays the status of the installed fans. If a fan is not installed, the state of the fan is Empty.
show fans
The following is sample output from an ExtremeSwitching switch:
FanTray information: State: Operational NumFan: 6 PartInfo: 0931G-00064 450237-00-05 Revision: 5.0 Fan-1: Operational at 14894 RPM Fan-2: Operational at 15360 RPM Fan-3: Operational at 15360 RPM Fan-4: Operational at 9637 RPM Fan-5: Operational at 9637 RPM Fan-6: Operational at 9637 RPM
The following is a sample output from a SummitStack:
FanTray-1 information: State: Operational NumFan: 1 Fan-1: Operational at 1000 RPM FanTray-2 information: State: Operational NumFan: 1 Fan-1: Operational at 1000 RPM FanTray-3 information: State: Operational NumFan: 1 Fan-1: Operational at 1000 RPM FanTray-4 information: State: Operational NumFan: 1 Fan-1: Operational at 1000 RPM FanTray-5 information: State: Empty FanTray-6 information: State: Empty FanTray-7 information: State: Empty FanTray-8 information: State: Empty
This command was first available in an ExtremeXOS 10.1.
Information about the current speed in RPM was added to the show fans output in ExtremeXOS 11.5.
